Great work with the feature to do calculations in repeats!
I have encountered a minor problem. When I add a geopoint in a repeat and makes it required - it is still possible to skip.
It works with other type of fields for example "Select one".
It is on iOS - 10.3.3 and Android 7.0 so I guess it is on all devices.
Thanks for the feedback - we will get this logged as a bug
I have found a workaround.
By adding a required field that reads the accuracy (treshold=25 m) of the geopoint it is impossible to leave the repeat without a collected geopoint.
