Republish survey missing label
2482
6
06-02-2023 08:36 AM
DrJumaKhudonazarov
I  updated the existing survey on Connect with a few new questions all was fine and published it without any issues. When i started the data collection the new labels I added were missing from the data section.  If I click on data I can see them in the form and also if I export the date to another format I can see them but not in the data section. Can someone help please what I need to do to change this?
Tags (1)
ZacharySutherby
Hello @DrJumaKhudonazarov
You may need to select the little plus button on the right hand side to display the column in the table:
Thank you,
Zach
DrJumaKhudonazarov
Thanks, didn't work any other tips  I can use?
Nicole_Ueberschär
Can you clarify again where you see them and where you don't? I understand that you see them in the form on the data tab but not in the table?
Are you sharing results? I think I would try to update the results view.
DrJumaKhudonazarov
Hello thanks. I see them in analysis section, i see them in exported excel sheet and i can see overall number of record that correct. I do not see the labels on data section,  i cliched the + button  to select all labels  but didn't work.  I had the same  with another survey and what i did copied the  same survey and republished it and it worked.
Nicole_Ueberschär
Hm, a bit strange. When you say labels, you mean you added questions (=fields), right? Did you try recreating the results view? Can you check in ArcGIS Online on the data tab of your layer if you see your added fields?
DrJumaKhudonazarov
 Thanks. Correct added questions will check on ArcGIS online  and let you know
