Report Generation with Survey 123
2175
10-10-2016 02:54 PM
MikeAndres1
I am looking for a way to generate a report from data collected in a Survey 123 project. I hear Data Driven pages is the way to go. If so, can someone explain this workflow?
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Mike,
Depending on what you are wanting as a report, there are several possible options.
Data Driven Pages enable you to create a layout/report for each survey response. Essentially, it uses a template layout and updates it for each feature as it steps through each row in the table.  Without any coding, the layout can include one or more maps (say, detail/overview) and attribute information.  With some python scripting to extract and maintain linkages, it can also include attachments.
Survey123's Analyze tab can provide a summary report of the surveys collected.  Further work can be done by exporting to a CSV and loading into another tool, like Excel.
MikeAndres1
Thanks James. I'm going to look into the Data Driven Page/Python workflow.
