Repeats and Time Stamp Overwriting
3239
13
03-01-2024 06:37 AM
DerekLittle
Since the latest update (Feb 2024) I am encountering a repeat time stamp issue.
My survey contains a repeat and the repeat items have individual dateTimes. When cycling through the entries or adding a new entry the dateTime is overwritten to the current time. Only happens after the minute changes.
This was not an issue until the most recent Survey123 update for iPads.
@ZacharySutherby
@IsmaelChivite
DougBrowning
MVP Esteemed Contributor
Have you tried once() or changing the calculation mode to manual?
DerekLittle
Reported as a bug through technical support.
TravisDrury
I think this is definitely a bug. I had a survey working fine until this month and then all of the times sent in were identical. I did change calculation mode to manual and it "fixed" it, but there isn't even a calculation in that field. So, it still just seems like a bug that happens to have a workaround that works for most people.
DougBrowning
DerekLittle
It appears changing the calculation mode to manual fixes the issue. Thanks @DougBrowning !
DanLissick
Hey Derek,
I am having the same issue and when trying to implement the calculation mode it didn't resolve it. Could you possibly provide your XLS form? Or provide a screen shot? It could help me solve this issue. Thank you!
DougBrowning
DanLissick
Attached is the XLS form, row 66 is what I tested the manual calculation. If you could take a look at see what you think that would be appreciated.
DougBrowning
I think the reason is line 67 with the if statement.  That is probably causing it to fire again.  That is a tough one then.  I am not sure if once() will help there as it may not calc in the correct order.  Other idea is to add calculationMode=whenEmpty to line 67 or a manual on that line also is worth a test.  Since it is a calculate type I am not sure what manual does in that situation.
Sorry all the ideas I have but you can test them.
DanLissick
Sounds good, thank you for the response!
