Repeated group return same value
1314
11-29-2022 05:34 AM
AliAwadBUK
I am trying to create a survey123 form with a repeated group but I have a problem
to fill out the repeated group we need to enter the data in the fields then click + to add another record, my question is how can get the same answer as the first record into the second, third,...
Note: the fields are text, integer and select one.
DougBrowning
MVP Esteemed Contributor
Do you mean a Same as the last record type deal?  If so then its a no without javascript.  But on large repeats this fails also.  I have been asking for it for years now.
https://community.esri.com/t5/arcgis-survey123-ideas/quot-same-as-last-quot-option-for-repeat-record...
javascript code
https://community.esri.com/t5/arcgis-survey123-questions/prepopulate-answers-in-a-repeat-with-last-v...
https://community.esri.com/t5/arcgis-survey123-questions/have-a-repeat-in-survey123-default-to-last-...
You can load a value into a field of a different name but not the same name.  123 cannot handle put Field A value in Field A.  It gets confused.  It is a major bummer that has been really slowing us down.  I am not sure they can ever fix it due to the way 123 works.  It is our crews number 1 gripe though for sure since our 20 year old system could do it.
If you meant you have a field outside the repeat that you want the value on in every repeat (like a key value for example) then all you have to do it have a field that does a calc to pull in the value outside the repeat.
hope that helps.
