Repeat questions in 'Inbox' not showing
11938
70
10-27-2017 07:57 AM
DanielKonzek
I enabled 'Inbox' for a survey with repeat questions.  I added the field 'bind::esri:parameters' to my survey and set the value to allowUpdates=true query=’1=1’ in this column for my "begin repeat".  I am able to view and edit my repeat questions from my "Sent box", but they do not show up  when I access a survey from my 'Inbox'.  Any suggestions?
Thank you,
Dan
by Anonymous User
Not applicable
Hi Joao,
Can you provide a copy of your xslx form so we can take a look? Do you have the Inbox enabled in the settings for the survey in Connect?
Phil.
João_CarlosPinto_Fernandes
New Contributor III
Hi Philip,
When I try to edit the file by the Inbox it does not show the images.
Then gives error and does not let edit the survey.
Thanks
Dowload
by Anonymous User
Not applicable
Hi Joao,
Attachments are not currently supported for editing in the Inbox, they will not be displayed either. This includes images, audio, signature questions types. There are some workarounds to enable adding new attachments in a survey when using the Inbox, but it requires having a repeat in the survey and adding a new record to the repeat.
We have an enhancement to support images (attachments) in the Inbox, and is high on our priority list to support in the future release.
Phil.
New Contributor III
Hi Philip,
It would be good to develop this feature soon.
Have other features I wish were possible.
Where can I put these ideas in the future?
Thanks
by Anonymous User
Not applicable
Hi Joao,
The best place to raise ideas, enhancements and bugs is with Esri Support. This ensures the issue is attached to your customer account and can be tracked and prioritised correctly. It also helps us understand demand for such features or enhancements and understand the requirements and use cases from all customers who log the same idea, enhancement or bug.
Phil.
New Contributor III
Hi Philip,
Thanks
New Contributor III
Hi Philip,
I have a problem.
I am following this manual (https://community.esri.com/servlet/JiveServlet/showImage/38-61392-448119/Edit_WebForm.gif) and cannot open my survey.
How can I overcome this problem?
I have an ArcGIS Enterprise.
Thank
JamesTedrick
Esri Esteemed Contributor
Hi João,
Are you trying to edit via the webform?  At this time, editing in the web form does not support repeats.
New Contributor III
Hi James,
Yes.
When we got over this problem.
Are you working on this?
Thanks
JamesTedrick
Hi João,
Support is in our plans, but we don't have definite date for this yet.
