Repeat questions in 'Inbox' not showing
23031
70
10-27-2017 07:57 AM
DanielKonzek
I enabled 'Inbox' for a survey with repeat questions.  I added the field 'bind::esri:parameters' to my survey and set the value to allowUpdates=true query=’1=1’ in this column for my "begin repeat".  I am able to view and edit my repeat questions from my "Sent box", but they do not show up  when I access a survey from my 'Inbox'.  Any suggestions?
Thank you,
Dan
JamesTedrick
Esri Esteemed Contributor
Hi Jeff,
In your XLS file, the parameters have
allowUpdates=true 1=1
You only should need
allowUpdates=true
the 1=1 is the default query and doesn't not to be there (and, as you noted in your comment, accompanied with the query= ).
Also note that single vs. double quotation marks matter in the case of the query; it should have been
query="1=1"
single quotes must be used for text inside a query, forcing double quotes only to encapsulate the query statement.
JeffPuuri1
Thanks for the clarification, James.  In fact I was just coming back here to update this thread with a report of success by simply entering the bare words
query allowUpdates
into the bind cell for the case where I don't need to filter anything coming back out during a refresh.  Thanks for pointing out the formatting nuances when further filtering might be necessary.
ShawnRoberts1
Hi Jeff, thanks for that update! I wasn't having any success with the bind parameter as allowUpdates=true or any variations of that. But your text of "query allowUpdates" solved the problem perfectly!
AndrewRyan3
Hi guys, I was wondering if any of you know if the "query allowUpdates" causes survey123 to not allow a repeat item to be deleted form a copied sent survey. the esri::bind::parameter is working great for me, but I need to be able to delete entire repeats for our new surveys that use copied sent data.  I think that allowUpdates, might be part of the problem. is there an allowDeletes? or allowTotalModificationAndDestructionOfRepeatData?
Thanks!
JamesTedrick
Hi Andrew,
The allowUpdates property does not allow for deleting repeat records; this is to minimize the accidental loss of data.  We have discussed an allowDeletes keyword to enable this functionality; I've listed your request in the discussion.
AndrewRyan3
OK great! Thanks for working through my terrible explanations to help me with this.
I would very much be interested in allowDeletes functionality, especially if I can control whether it is enabled for the inbox, or just for the sent surveys. I absolutely understand why locking down deletes is preferable to a lot of users, and for my users, accidentally overwriting a previously submitted days data thinking you were creating a new survey would be bad news.
thanks again.
by Anonymous User
Not applicable
I too would like to have the allowDelete functionality
by Anonymous User
Not applicable
Hi JTedrick-esristaff‌,
The allowUpdates query doesn't work with image type questions.
  1. Doesn't let you edit on previously sent images
  2. When adding additional images (edit pane) to a previously sent survey, none of the new images are saved in related tables (but duplicates of previously sent images).
Could you please look into this?
Gee
JamesTedrick
Hi Geethaka,
Yes, allowUpdates does not allow for the updating of images at this time.
João_CarlosPinto_Fernandes
I have the same problem and need a solution.
Have you found a solution?
