Remove Tile Packages From Linked Content in Survey123 Connect
2546
10-31-2020 07:41 PM
GarrettSmith1
Hello
Does anyone know if  you can unlink tile packages from the linked content pane in Survey123 Connect? I have three tile packages that I want to unlink from a survey I am working with.
Thanks
ZacharySutherby
Hello Garrett Smith‌,
When you select the three dots to the right of your linked tile package there should be a red unlink icon:
Thank you,
Zach
Thank you,
Zach
IlkaIllers1
Hi Zach,
what if there is no unlink icon? I have several tpk which I would like to remove to make the offline area less cluttered, but there simply is no unlink button:
Ilka
BenSEBatHub
Same issue here.
AllisonWebb
I have the same issue.
Cyprus_Forest_Department
same here
