Remove Space from Table Generated from Repeat in Survey 123 Feature Report Generation
999
05-27-2020 11:36 AM
FredKellner2
I am using a feature report template with Survey 123 and I am generating a table off of a repeat in my Survey.
I have successfully generated the table however, each time I create a row from a repeat value it adds a return carriage in between each row of my repeat values:
This is what I am currently getting
and this is what I would like the report to look like
I have tried numerous different methods of putting the start and end of the repeat inside and outside of the table, but still end up with this carriage return.
James Tedrick
JamesTedrick
Esri Esteemed Contributor
Hi Fred,
Apologies for the delay in response.  It would be helpful to see how you constructed the template.  You should be able to get the format you want by beginning and ending the repeat within a 1-row table; I suspect that the begins and end repeat components are outside the table.
