Is there a way to remove the automatic scroll in Survey123? I'm developing a simple survey and adding a fifth column causes a scroll to be incorporated when it's not necessary (plenty of space in browser):
Solved! Go to Solution.
Hello @KateDoughty1,
The width URL parameter isn't exclusive for embedding surveys, your can append it to the URL you are providing and when a user opens that URL they will see the wider form:
After you publish your survey you can use the width URL parameter to make the width of the survey a little wider and remove the scroll bar.
But I'm not embedding it - just providing the URL so I'm not seeing the option to modify.
