Remove scroll on Survey123
1420
03-24-2023 11:40 AM
KateDoughty1
Is there a way to remove the automatic scroll in Survey123? I'm developing a simple survey and adding a fifth column causes a scroll to be incorporated when it's not necessary (plenty of space in browser):
ZacharySutherby
Hello @KateDoughty1
The width URL parameter isn't exclusive for embedding surveys, your can append it to the URL you are providing and when a user opens that URL they will see the wider form:
Thank you,
Zach
ZacharySutherby
Hello @KateDoughty1
After you publish your survey you can use the width URL parameter to make the width of the survey a little wider and remove the scroll bar.
Thank you,
Zach
KateDoughty1
But I'm not embedding it - just providing the URL so I'm not seeing the option to modify.
ZacharySutherby
Hello @KateDoughty1
Thank you,
Zach
