Remove blank responses from percentage analysis
1772
05-22-2019 08:38 AM
JevaughnHenry
When will we be able to get the percentages for the results of a question to exclude the skipped responses in the Analyze tab?
I know this is possible by filtering, however this affects all questions outside of the target question. Will a simpler method be implemented such as a toggle on each question to exclude blank responses from the analysis?
James Tedrick‌ Ismael Chivite
JamesTedrick
Esri Esteemed Contributor
Hi Jevaughn,
Which question type(s) are you requesting this for?  You should already see an 'Empty Categories' option to check/uncheck for single/multiple choices.
JevaughnHenry
Hello James,
This is in regards to both single and multiple choice questions. I am referring to the number answered and the number skipped. Is it possible to remove the skipped count from the calculation of the overall percentages for the other results for a question without affecting the other questions outside of the target question?
I know that filtering individual questions can allow for this, however it affects other unintended questions.
JamesTedrick
I've taken down an enhancement to add 'skipped' as a category that can be hidden (in the same way as empty responses)- that way the statistical impact would be explicit and optionally hidable.
PBBennetch_columbus
What is the status of this idea/improvement, and how/where can I vote for that request?
