Regular expression for a person's height
1635
06-11-2020 12:58 PM
ryanEvanczyk
I used an online regex checker and I've got what I want to work, but it won't work when I put it into my form via survey 123 connect.
regex(.,'^(\d)\'(([0]\d)|([01][01])|(\d))\"$')
I've had a similar issue before and simply retyping it vs copy/paste solved the issue, but not this time.
I'd like the examples 0'11", 9'11", and 9'1" to all be valid.
Thanks for the help,
RyanE
Tags (1)
DougBrowning
MVP Esteemed Contributor
You could use 2 fields then you could check for like 4-6 on feet and 0-12 in inches as well.  Can then combine them after in a 3rd field.
Just an idea.
ahargreaves_FW
I too am struggling with this. I'm using:
regex(.,'^([1-8]')?\s?([1-9]|1[01])$')
@IsmaelChivite , @JamesTedrick  any insight?
