Regex not taking
507
03-31-2026 12:43 PM
ChaceCarpenter
Hello, I am trying to limit an address input in Survey123 by adding a constraint . I am using the regex below to achieve this goal.
regex(., "^(\\d{1,})\\s{1,}(North|South|East|West|N|S|E|W|NE|NW|SE|SW)\\s{1,}(\\w{1,})\\s{1,}(\\w{1,})((,{1}\\s{1,})|\\s{1,})(North|South|East|West|N|S|E|W|NE|NW|SE|SW),\\s{1,}(\\w{1,}),\\s{1,}(\\w{2}),\\s{1,}(\\d{5})$")
I used this same regex in a python script with success, so the logic is correct. I'm not sure what I am doing wrong. Am I missing something?
Note: The regex should accept an address with the following format: "111 N Street St N, City, OH, 44444"
AlfredBaldenweck
MVP Frequent Contributor
It's probably the escaped backslashes. since then it's looking for the literal text "\s" instead of the space characters.
For python, you can avoid these by using r"\s", for S123 you can just put them in.
Here's one of mine
regex(., '^(WYWY\d{9})$|^(WY[A-Z]\d*[A-Z]?)$')
ChaceCarpenter
If i'm understanding you correctly, you are saying I can replace a \s with an actual space? So my above regex would look like: regex(.,"^( [0-9]{1,}) {1,}(North|South|East|West|N|S|E|W|NE|NW|SE|SW) {1,}([[a-zA-Z0-9]{1,}) {1,}([[a-zA-Z0-9]{1,})(?:,{1} {1,}| {1,})(North|South|East|West|N|S|E|W|NE|NW|SE|SW), {1,}([[a-zA-Z0-9]{1,}), {1,}([[a-zA-Z0-9]{2}), {1,}( [0-9]{5})")
I also replaced \d with [0-9] and \w with [a-zA-Z0-9]
AlfredBaldenweck
No, I mean you have
and you should have
regex(., "^(\d{1,})\s{1,}
