Record time in correct time zone
13676
14
03-27-2019 10:18 AM
WhitneyWeber
When collecting data via my Survey123 with a field type of dateTime and bind::esri:fieldType of esriFieldTypeDate, the time displays correctly, but is recorded 4 hours different (presumably UTC). How do I get the recorded data to reflect the correct time zone? Do I need to record it in a different field of type calculate with something like now().toLocaleString or now()+int(2400) (2400 because 60*4hours)? I would think this would be a common question, but can't find it anywhere.
wild_ecology
Hi Toby, did you ever figure out a solution? I'm running into the same error message.
@TobyStewart2 wrote:
Hi James
Sorry to open an old post but I used the above in a survey and it all goes through Ok, except when I test the submission of the survey and I get the following error
"bigint is incompatible with datetime2"
Any suggestions?
IvanZamora
Got the same problem. All works fine if I fill the survey from the app but if I want to fill it from the browser fo people who can acces to the app, this bignit error comes. Did you solve the problem?
Sorry for open a very old conversation
MaxwellMoore
Can you please provide an explanation of how to use this in a survey that has a repeat section? The example provided causes the date/time to be blank in the main survey download and I am confused by the explanation provided to Whitney for their survey. Please.
GaryEnnis
This solution worked for me. Thanks James.
WhitneyWeber
Sorry, I forgot to mention that I have visit_date with a default value of now(). I did not repeat that in the visit_date_local field, assuming it pulls it from the visit_date field.
