Date/Time error now in web version only
3407
5
11-24-2021 11:26 AM
by Anonymous User
Not applicable
I have a Survey123 built in Connect that we've been using for 6 months.  It's mostly used on mobile device, but some folks use the webversion to back enter records.  Starting sometime with the last month, the Date and Time field are throwing an error:
"Operand type clash: bigint is incompatible with datetime2"
I've tried entering various dates and times to no avail.
I found one post that suggested changing the web setting to always use the latest version.  I did change that but we were using the latest version already so that did nothing.
Update, I have a second date/time field (for the Excel non-UTC aware) that uses this calculation behind the scenes. It seems my issue is related to this since when I remove that field & calculation I get no errors.
${EventDateTime} + pulldata("@property", "utcoffset")*1000*60*60
I have changed my web to use the latest version, I checked that I have version 3.13 for Connect, and I have republished the survey.
I thought that the pull data and @ property is supported in web now?
Any ideas?
alison_gou
Hi @Anonymous User ,
I tried to reproduce your issue but I failed to encounter the same issue, my second question in web app ends up empty. Can you share one xls form so I can reproduce this issue?
Regards,
Alison
by Anonymous User
Not applicable
Hi Alison,
Sure thing, I attached it here.
Thanks!
by Anonymous User
Not applicable
I have the same problem: I have a dateTime question, where I get UTC value, then there is a calculate question with field type set to esriFieldTypeDate. Works fine with field app, web form returns same error when submitted.
wild_ecology
I also have the same problem. Is there a work around?
IvanZamora
Hi, got the same problem, did yo solve it?
