Ranges of Time in Survey123
717
05-15-2018 10:31 AM
deleted-user-jxpbpbjlZInj
I'm wondering what my options might be for entering a range of time into a single field? I.E. If someone doesn't know an exact time that something happened, then I need them to be able to enter it as a range of dateTime.
I've thought up some creative ways using the Collate Field function, but I'm hoping there is something more elegant out there.
Sunny#
Tags (1)
JohnathanHasthorpe
Hi Sunny
DateTime questions can't store ranges - so you have a couple of options:
1) Have separate start and end DateTime Questions
2) Do 1) but set the DateTime questions to be null in the bind::esri:fieldType (so that they don't persist) and then format and combine the values in a text question.
You can use format-date and concat() for this.
Cheers
John
