"No Surveys" using Survey123 web site with ArcGIS Enterprise 10.5.1
713
12-20-2017 11:22 AM
TimothyMichael
I have migrated surveys from ArcGIS Online to ArcGIS Enterprise, and opened the Survey123 web site to test viewing the results there.  I have the following:
  1. ArcGIS Enterprise 10.5.1
  2. Using PostgreSQL for the database and published services via portal/server - configured surveys to use an existing feature service for submissions
  3. Accessing the Survey123 web site via the URL https://survey123.arcgis.com/?portalUrl=https://<fqdn>//portal
  4. When I sign in as the user that owns the surveys, I can see results - everything appears to be working.
  5. When I sign in as another user:
    1. I see a 'No Surveys' message with the note 'No survey results have been shared with you'
    2. This user has a valid enterprise account and is able to view / submit survey records
    3. Survey form and feature layers have been shared with the user via a portal group
    4. I see the same message when I choose All Surveys, Surveys I Own, or Surveys Shared With Me
Following the instructions in the message to share survey results I attempted going to Collaborate > Analyze and get the message 'The feature is not available.  Hosted feature service views is not supported by your Portal for ArcGIS.'
Is there additional configuration needed to allow non-owners to view the survey results in the Survey123 web site?
Tim
by Anonymous User
Not applicable
Hi Tim,
Could you please provide more information on how the original surveys were created (via Connect or Web and which version/timeframe) and then the steps of how you migrated the survey and feature service to Enterprise?
This information will help in troubleshooting this issue further.
Regards,
Phil.
TimothyMichael
Hi Phil,
  • I'm not 100% sure when the surveys were originally created, but I would guess within the last year or so.  Also unsure of original creation method (Connect vs web)
  • For each survey, I downloaded the feature service data from ArcGIS Online as a file geodatabase.  The data was migrated into an enterprise geodatabase and feature layers were published to portal to correspond with each survey
  • Signed in to Survey123 Connect (using version 2.5.44) and downloaded copies of each survey
  • Updated each survey (field names, submission url, etc.) and published to portal
  • Shared Form and Feature Layer items with portal group.
Let me know if you need any more information.
Thanks!
Tim
