Question about uploading
3478
08-28-2015 03:22 PM
Joseph_Kinyon
I am in the process of publishing my first form.
The "Updating Service Details" dialog window has a full blue bar but the hourglass-circle has been spinning for well over an hour.
If I have XLS Form Types that are currently "highlighted yellow" would this account for that behavior?
Joe
IsmaelChivite
Esri Notable Contributor
Hi Joe. Uploading surveys takes a few seconds, typically no more than 15. If you are using XLSForm questions or elements that are highlighted in yellow in the support for XLSForm in Survey123 for ArcGIS help document, you may want to remove them for now.  Using non supported elements may cause issues when attempting to publish or use the survey.
To get things back clean, I recommend that you delete the survey completely before you try to publish again. You can have a look at this to make sure your survey has been properly deleted.
IsmaelChivite
