I have a survey I created in late 2020 that has a select_multiple field. I was asked for records that met a certain criteria, which included some but not all the values that are possible in that field. I went to the Data tab on the page for the survey, set a query using multiple 'contains' and 'or', and then attempted to Export to .xlsx or .csv or .gdb, but it just spun and I didn't get any output.
So, I pointed ArcGIS Pro at the feature service, and then attempted to set a query, but found it would not see one of the possible values in that field (which is very odd).
Then I tried setting a Filter on the layer in Map Viewer, which worked, except MapViewer is not displaying the values correctly...
I seem to have worked around some problem with the querying and exporting here. How can I get this querying to work directly in the Survey123 Dashboard, and also have the values display correctly in the MapViewer filter?
