Query attributes from Survey123 connect
282
2 weeks ago
Fiona
I want to query attributes from a polygon feature layer using a geoshape in Survey123 Connect (3.25.27).
How can this be handled when the geometry intersects multiple polygons?
Best regards,
Fiona
Neal_t_k
MVP Regular Contributor
The pulldata("@layer") function only accepts geopoint geometry for "getValueAt" and "getRecordAt".  You should be able to use the search appearance to return of list of the overlapping polygons from a geoshape question and identify in that list the one you want attributes for.  Then feed that into the pulldata ("@layer") to get the attributes from a specific feature.
Neal_t_k
Fiona
Appreciate the tip, I’ll verify it.
