pulldata(@layer) does not work in public (with secured layers) surveys
1840
02-29-2024 09:15 AM
PanGIS
Hello!
I was so proud of myself,
a survey was working so well limiting applications when the limit was reached. [pulldata@layer and getCount]
It counts the application per type and if each of them reaches a certain number it does not allow to submit.
Wonders! @IsmaelChivite this was the best update ever!
But only if you are logged in!
the layer is public but I followed these steps to prevent the query, of course if you cannot query you cannot know how many application there are....
I screamed today when I saw a new application was submitted when the limit was already reached.
Any hint?
I was thinking of providing the user with a login so at least the data is not completely public.😢
thanks!
Tags (3)
abureaux
MVP Frequent Contributor
I haven't done this type of set-up before, but couldn't you set up a public view with non-Personally Identifiable Information (PII) and then use your pulldata on that layer to determine submission count?
jcarlson
I concur, and would add that we have done this very setup a few times. The public endpoint for the form is not query-able by the public, but we use a separate view for "safe" fields only so that certain pulldata expressions will work.
- Josh Carlson
Kendall County GIS
PanGIS
I will test it tomorrow morning but I want to hug you already 😅
The public info I need to query are not sensitive, it could work.
I will let you know if it works!
