Pulldata from a Geotrace (Location)
350
5
05-21-2024 02:42 PM
DianaTorres10
Hi there.
I'm currently working on a survey in 123 connect.
I was wondering if it's posssible to retrive information with a pulldata from a geotrace question, like X & Y coordinates from the start point and end point of a drawn line.
Thank you all!
You can find my xlsx below.
abureaux
MVP Regular Contributor
You can select a feature in a web map and launch a survey from there. Then you will use URL parameters to pull that data into the survey.  See Survey123 Tricks of the Trade: Web form URL parameters
Then there is the trusty pulldata("@layer"), which may also be a good fit for you. See Survey123 Tricks of the Trade: pulldata("@layer")
DianaTorres10
I wanna retrive the information from a line drawn by the user at the time of submiting the survey, I'm not working with existing features.
abureaux
Ah, my apologies. In that case, there isn't a solution. There is no equivalent to pulldata("@geopoint") for geotrace yet.
DianaTorres10
Would it be possible to use 2 different geometry cuestions and use the pulldata from the geopoint question?
abureaux
If you are working with a geopoint question, then you can use any of the pulldata("@geopoint") options. So yes, you could pull location data from two separate geopoint questions easily.
