Pulldata constraint stops working in browser, but functions fine when viewing in survey 123 connect.
340
04-07-2026 12:39 PM
JoshuaCampion
I'm currently creating a survey to give citizens the ability to reports issues that they see on our highways. I created a buffer around the highways that are our (County Gov) responsibility to maintain. I then set a constraint for the geopoint question to confine responses to that polygon. It works fine when viewing the survey in connect, then I opened it from ArcGIS online in a browser window, and now it won't allow points to be submitted even within the set polygon. I read that the pull data line doesn't transfer over from the app to a browser well. Thanks for any ideas!
Neal_t_k
MVP Regular Contributor
Can you share the relevant parts of your xlsx or or pulldata calc?
JoshuaCampion
pulldata("@layer","getValueAt","attributes.boundary","https://services1.arcgis.com",${location}) = "valid"
Since posting this I've realized that the problem might be that I'm running an attribute check rather than a geometry check, but still not sure. I also shortened the link for the purpose of posting here it contains more than just services1.arcgis.com. Location is the name of the geopoint question.
Neal_t_k
I would start by putting just  pulldata("@layer","getValueAt","attributes.boundary","https://services1.arcgis.com",${location})   in a calculation to see what it is returning, and if it is returning correctly in the web app as well. Then if that is working correctly in the constraint field put . = "valid"  assuming "valid" is what the calculation is returning.
