pull data function returning 400 Invalid URL
1871
09-10-2023 07:57 AM
MichaelKohler
I've been using the Damage Assessment Solutions that includes Survey123 Connect XLS forms. Part of that is the JavaScript functions that should pull data from a feature service and use the data to populate a field in the survey. I keep getting a 400 error saying the URL is invalid. I've even created a URL that I know works and short circuited the JavaScript code and still get the invalid URL error. I've had this working in other surveys, just not the damage assessment.
This is how the function is called from the XLS
pulldata("@javascript","myJSFunctions.js","queryPolygon",string(${location}),"PARCELID",pulldata("@property","token"),true)
Below is the code in the scripts folder.
function queryPolygon(location,fields,token,debugmode){
    if (location===""){
        return (debugmode? "Location Object is empty":"");
    var featureLayer = "https://services1.arcgis.com/**********/arcgis/rest/services/RE_PARCELS_WEB/FeatureServer/0";
    var coordsArray = location.split(" ");
    var coords = coordsArray[1] + "," + coordsArray[0]
    var xmlhttp = new XMLHttpRequest();
    var url = featureLayer + "/query?geometry=" + coords + "&geometryType=esriGeometryPoint&inSR=4326&spatialRel=esriSpatialRelIntersects&outFields=" + fields + "&returnGeometry=false&returnCount=1&f=json"
    if (token){
        url = url + "&token=" + token;
    xmlhttp.open("GET",url,false);
        xmlhttp.send();
    if (xmlhttp.status!==200){
        return (debugmode? xmlhttp.status:"");
    } else {
        var responseJSON=JSON.parse(xmlhttp.responseText)
        if (responseJSON.error){
            return (debugmode? JSON.stringify(responseJSON.error):"");
        } else {
            if (responseJSON.features[0]){
                return JSON.stringify(responseJSON.features[0]);
            else{
                return (debugmode? "No Features Found":"");
 This is the error that is stored in the JSON field. See Picture
{"code":400,"message":"Invalid URL","details":["Invalid URL"]}
Then I created a url that I know works and hardcoded it into the code and still get the same error.
    if (location===""){
    var featureLayer = "https://services1.arcgis.com/***********/arcgis/rest/services/RE_PARCELS_WEB/FeatureServer/0";
    //short circut url with known url that works when pasted into browser.
    var url = "https://services1.arcgis.com/**********/arcgis/rest/services/RE_PARCELS_WEB/FeatureServer/0/query?geometry=-80.39273,27.21473&geometryType=esriGeometryPoint&inSR=4326&spatialRel=esriSpatialRelIntersects&outFields=PARCELID&returnGeometry=false&returnCount=1&f=json"
    if (token){
        xmlhttp.send();
    } else {
        } else {
            else{
Any ideas would be greatly appreciated. As well on what the debug mode is and how would someone debug this code.
MichaelKohler
Good news, it's working. Bad news, I'm not sure what exactly happened.
What I think happened is that there is some sort of disconnect between the code in the script window and the js file in the scripts folder. What I ended up doing was l tried to launch the script in an editor and then made changes. It just seemed to flip a switch or something and then the survey worked as expected.
MichaelKohler
