Pull data from select_one_from_file with a query on the same form
873
06-25-2025 09:06 AM
Harris_Koffi
Good morning,
I would like to fill a field on my form with the values of another field on the same form.
I have the project code field that I would like to fill with the code values already entered.
How can I do this?
Thank you.
Neal_t_k
MVP Regular Contributor
Are you asking to have choice based on previously submitted answers, or a list based on answers from the same session?
If it is the prior, this might be what you are after.  Only works for online.
https://community.esri.com/t5/arcgis-survey123-blog/dynamic-choice-lists-using-search-appearance/ba-...
Neal_t_k
Harris_Koffi
Yes, exactly. Thank you, it is done !
I have ArcGIS enterprise and I replaced the url in autocomplete with the one for my featureServer and it works.
