pull data from related table into survey
997
05-25-2023 03:56 PM
CoreyWilliamsESRIAccount
Is it possible within Survey123 to surface the username of who created each repeat?  I am looking to concatenate then join, outside of the repeat, the data from a select one question, the username and open text.
Tags (1)
ZacharySutherby
Hello @CoreyWilliamsESRIAccount
Within the repeat you can add a question that uses pulldata("@property", 'username') in the calculation column. Anytime someone adds a new repeat value the username will be extracted and added to the repeat record. You can also set the calculationMode to whenEmpty to ensure the calculation only runs when the repeat is added ensuring the value isn't updated if the repeat is updated.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
