Pull data from csv into webform
5169
10
02-12-2017 07:27 PM
tomhughson
Hello there, are there any known limitations in getting the pulldata from csv function working on a web form? Seems to be functioning well when testing in survey123 connect but after publishing the relevant information is not being pulled into the form. I also can't submit the survey, I get this 'loading' message at the bottom of the survey form. The same form lodges OK from the iphone app (but the pulldata from csv also doesn't seem to be working on the iphone). ?? Thanks
Tags (1)
TKSHEP
I am trying to do the exact thing, would you be will to share with me how you set up the barcode to read information form a csv and populate the fields that it finds such as in your example you used.  I would greatly appreciate it.
