Publishing failed to complete: error 400
3580
06-17-2020 07:09 AM
GISManager4
Publishing new survey receive error; Unable to add feature service definition. Folder is created in ArcGIS Online.
Connect Survey123 for ArcGIS v3.9.120
Tags (1)
ZacharySutherby
Hello,
Thank you for passing along the XLSForm! In taking a look at the XLSForm it looks like there are a few duplicate field names down in the groups. On lines 52-56 within the dpr_value group, the question names are the same as the questions on lines 42-46. This is the reason the publishing is failing when adding to the service definition because it can't add fields with the same name to the service.
I had changed the questions in lines 52-56 to value3_XXXXX and the form published as expected to my ArcGIS Online Organization.
Alternatively, if you would like to keep the same field names you can switch either the value2 or drp_value groups to a repeat so that those fields are added to a related table instead of the root feature service.
Thank you,
Zach
Thank you,
Zach
IsmaelChivite
Esri Notable Contributor
Hi. To properly diagnose this issue, you will need to share your XLSForm file. You can share it in GeoNet as an attachment, or you can share it with an Esri Technical Support analyst by opening a Tech Support case.
GISManager4
Not an issue, please see attached XLS form.
ZacharySutherby
Hello,
Thank you,
Zach
Thank you,
Zach
GISManager4
In previous versions, duplicates would have been flagged when saving the XLS form. I made the changes to the name field and it successfully published. Thanks.
