Publishing Error 500
770
01-30-2020 08:23 AM
UGMLANAMME
I´ve finished my survey on Survey123 Connect desktop app, in the publishing process I got an error, as shown on the image below. Any ideas on how to solve this?
Shwu-jingJeng
You could turn on the diagnostics from Connect Settings. Thne publish the sruvey again and wait for the error to occur. Go to the log output location and check the log, it should list the detailed info regarding the failure.
You may attach your log here for us to check for you if you like.
