Public Survey - autopopulate field based on pulldata function
2050
09-01-2021 07:13 AM
RosemaryHatch
I have a public facing Survey 123 (built through Connect) where users select the location for an application. A report then gets sent via an integromat webhook to our office. I would like to have the location of the geopoint determine who receives this email - I think I can do this using a pulldata javascript function (aka autopopulate a field based on an intersection with an existing feature layer), however I don't believe js works for public surveys.
Is there a workaround, or a creative solution for making this happen? It would be very useful for our workflow.
IsmaelChivite
Esri Notable Contributor
Hi. If the survey is public, you cannot use a custom JS function to do the spatial query. However, I think it would be best to do that in Integromat anyways. In Integromat, you can use the HTTP module to make a call to your feature layer through the ArcGIS REST API, then parse the JSON response to figure out who should receive the email.  There is some info about how you could do the query in this blog post: https://community.esri.com/t5/arcgis-quickcapture-blog/data-enrichment-with-arcgis-quickcapture-and/...
IsmaelChivite
RosemaryHatch
Hi @IsmaelChivite
What are the security issues with using integromat in this way? As I delve deeper, it does look like it's best to not use webhooks at all with public surveys? Or at least use hosted feature layer views - which pose a problem when trying to update features.
Thanks!
Rosemary
RosemaryHatch
That seems like what I was looking for - will take a bit to test it out. Thanks!
