Problem with where clause in pulldata("@layer"...)
1517
6
11-07-2025 10:46 AM
ZenMasterZeke
Having trouble with the where clause in a pulldata("@layer"...) calculation. I have two surveys: one where a user is given a user name (field name user_name) for logging in and enters their information such as name, address, etc. Records in the first form will be unique users.
The second form is where the user logs in with the same user name (field name user_login) and enters resources they have. There can be multiple records per user in this form.
I want to pull a separate field from the first form (organization_name) where the username from the second form matches the username from the first form. (This is basically creating related tables/joins, but the Web Designer doesn't support them, afaik.) In other words, return fom1.organization_name where form1.user_name = form2.user_login.
My calculation is
pulldata("@layer", "getValue", "attributes.name", "https://services.../FeatureServer/0", "user_name=user_login")
But whenever I run this, I get an error that there is no survey element named ${user_name}. I've tried using the ${} format on one field, both, the other, switching the order of the fields, etc. Is there a way to do this? Thanks!
Neal_t_k
MVP Regular Contributor
try putting the where clause in a helper field
whcl = concat ("user_login = '",${user_name},"'")
pulldata("@layer", "getValue", "attributes.name", "https://services.../FeatureServer/0", ${whcl})
user_login = the field in the feature layer you are querying
user_name =  the name of the question in the form you are using to match.
Neal_t_k
ZenMasterZeke
Thanks @Neal_t_k . I'm not getting an error anymore, but it's not returning anything either. The where clause -
type    name    label           calculation
hidden	whcl	Where clause   	concat ("user_name = '",${user_login},"'")
returns: user_name = 'ZenMasterZeke', which seems correct. The pulldata field is
text  org   org    pulldata("@layer", "getValue", "attributes.name", "https://services8.arcgis.com/IGysY44dU9lNnAZQ...FeatureServer",  ${whcl})
but nothing is returned. I've verified that name is the correct attribute,  the feature service id is correct, and user_name in the @layer feature layer = user_login in the querying layer. The full section of the xlsform is
username	user_login	Login name																		hidden	        whcl	        Where clause   concat("user_name = '",${user_login},"'")
text	        org	        Org	       pulldata("@layer", "getValue", "attributes.name", "https://services8.arcgis.com/IGysY44dU9lNnAZQ.../FeatureServer",  ${whcl})
note		               ${whcl}
Can't figure out what's wrong 😕
Neal_t_k
ZenMasterZeke
@Neal_t_k ,
Thanks, but that didn't work either
Edit -hmm, user (me) error. Survey is on one portal, I was using layer from a different one. Duh... Thanks though!
Neal_t_k
When you look at the service is query enabled?
ZenMasterZeke
I will check that as well.
