Prevent PDF's From Being Uploaded
1547
04-14-2021 08:07 AM
JoshBillings
Hey all,
In my survey, I have an option to upload an image. The question type is set as "image" in the XLS form.
However, participants in the survey can still upload PDF files. Is there a way that I can prevent PDFs from being uploaded?
Josh
Tags (4)
Andrew-Bowne
Are you using the Web Designer or Connect?   It looks like you can restrict file types with the web designer but not (at least according to this reply) with Connect.
https://community.esri.com/t5/arcgis-survey123-questions/file-upload-types/td-p/872726
JoshBillings
Thanks @Andrew-Bowne. I am using Connect. Looks like I'm not able to do this at this time.
