Prepopulate a selection within a repeat
436
06-03-2026 09:08 AM
JessHedgpeth
Hello all,
I am trying to set the default selection of a drop down list within a repeat to be the previously selected option. I have included the table below for reference.
begin repeatWin_PointsMapped Points
select_one cow_codecow_codeCowardin code:   minimal   ${previous_cow_code}
integerORD_codeORD Code  numbers  yes 31000+(position(..)-1)
geopointsurvey_pointsPoints
textOHWM_noteNote:
end repeat
So, if they select "OHWM" as their cow_code during the first repeat, is there a way to make cow_code automatically default to "OHWM" until they change it? And then, if they do change it to "PEM", can it automatically default to the new selection now instead of "OHWM"?
I've tried my hand at a couple of different options, but so far I don't think I'm using the correct code, or not putting it in the correct place.
Thank you!
Neal_t_k
MVP Regular Contributor
There currently is  not a good way to do it. You can populate the hint with a previous answer or I think @DougBrowning has a JavaScript for it. It is something that is wanted for a while. But any calculation of from the same question in a previous repeat ends in a cyclic redundancy. Hopefully in the next iteration.
See:  Solved: Duplicate previous repeat values? - Esri Community
Prepopulate answers in a repeat with last values - Page 3 - Esri Community
Neal_t_k
JessHedgpeth
Dang. That's what I was running into - with it being a cyclic redundancy on the survey side. I appreciate you popping the references to the community forum posts here - I searched it (I figured folks had this issue before) but couldn't hit on the right search terms.
Thank you for your help!
