Polygon changes over time
651
06-23-2020 09:07 PM
RadkaWildova1
When recording new survey is it possible to display your real time location on a background map that shows previously recorded polygons? In our survey those polygons will indicate areas infested by invasive plants, and we would like to see, while in the field doing the follow-up survey, if the size of the infestation stayed the same or got bigger. Thanks
Shwu-jingJeng
Hi Radka,
Have you subscribed to your EAC yet? Using 3.10(will be released soon) version of Survey123, you could set a default basemap using the linked content in Connect. Please check this post from our EAC program to check how to set the default basemap with Linked content:
Organizatgion Basemaps and Linked Content
Welcome to our Customer Validation site.
