Passing Parameter from Field Maps to Survey123 INBOX Edit
1618
04-06-2022 11:15 AM
m3
I am trying to pass an attribute from Field Maps to Survey123, much like the normal usage
field:uniqueID={uniqueID}
But in this case I need to pass the parameter into an Inbox Edit.
This is what I've tried so far.  Is it even possible?
arcgis-survey123://?itemID=XXXXX&portalUrl=https://portal.url.com&action=edit&folder=inbox&filter=globalId:{GLOBALID}&field:uniqueID={uniqueID}
Thanks
HuubZwart
You need to pass the globalId parameter as well (globalId=, filter only filters the inbox) to open a record directly. Also, you may need to pass the query parameter (q:OBJECTID= for example) to query the record if it isn't in the inbox yet. Finally, you may need to pass update=true to reload the inbox on opening the link. Hope that helps!
m3
bump
m3
Yes, it's not in the inbox yet.
Where would the OBJECTID query go?  Into the URL?  What is the exact syntax?  I've tried a few things and can't get it to work yet.
Not surprisingly I can't find any documentation on this.
ChristopherCounsell
MVP Regular Contributor
What version of Survey123 are you on? Use the latest to avoid issues i.e.
https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDEzNzY3OQ==
Documentation is available here:
https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm
And here:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/prepareforediting.htm
I would suggest checking your Inbox is working first and the field can be edited. There's guides on this:
https://youtu.be/rrQZNaqcCYI?t=272
After than, if the feature is not in the Inbox, the update parameter identified by HuubZward will fresh the inbox.  The query parameter will retrieve content not on the device. The above page 'integrate with other apps' talks more about what each parameter does
m3
arcgis-survey123://?itemID=ITEMID&portalUrl=https://PORTAL.URL/arcgis&action=edit&q:objectid={OBJECTID}?folder=inbox&update=true&filter=globalId:{GLOBALID}&field:unitid={expression/expr2}
I'm on the latest version
I've read the documentation
The inbox is working
I'm able to open the proper record in the Survey123 via the link in the popup
The inbox is not refreshing
The field:field=value parameter is not being passed either
