Participant location data
805
10-10-2018 01:23 PM
YvetteFreake1
Is it possible to have a survey that does not collect participant location data in Survey123? I do not require this data and don't want to see it in the results if possible. My participants need to remain anonymous. Thank you!
JamesTedrick
Esri Esteemed Contributor
Hi Yvette,
There are a couple of approaches:
1) If the survey is being collected over the web, not including a point question will accomplish this as the results will be located at 0,0
2) You can accomplish this be creating a table in ArcGIS Desktop tools for the survey to write to and publish it in a feature service.  Creating a form to work with the table will not have a point question and will not record location.
