Ownership based access to a parent and child feature service by two different users
658
03-18-2021 10:55 AM
CharlieColey123
Hi
I need
1. user 1 with role A to only be able to edit the asset features they create
2. user 2  with role B to be able to create a related inspection record for the asset and not be able to edit any other inspection records created by other users with  role B
So in AGOL I  set up a feature layer view on the feature service
User 1 with role A creates the parent feature in S123 with the "create feature form" - created by field = user1
User 2 with role B logs in and uses inbox to view the parent feature in the "create inspection form"
If user 2 tries to edit a parent feature field and submit the form then S123 behaves as I would expect (send error), but if user 2 only edits the related record  the same error is shown.
No edits are being made to the parent owned by user1 so why is user2 not allowed to create a new record?  something to do with the relationship class?  or is a submission treated as an update event to the parent too by S123?
If so can anyone think of a way around this.  If it was enterprise i would publish separate services
Thankyou
Charlie
CharlieColey123
I've tried the same editing scenario by adding the item to Pro and same issue, Pro won't let another user add a related record t the parent if the parent is created by another user - so not S123 issue - just facet of AGOL authorisation model
