Overwriting time question when cycling through repeats
4957
14
05-15-2024 06:09 AM
GeorgeClutterbuck
Using survey123 connect I have created form containing repeats which contain a time field. If I cycle through the repeats once filled out, the time field for all the repeats change to the most recent entry. I've tried using the once( function and changing the bind parameters to manual calculation and this works fine before publishing the survey on desktop, but the error perists on the field app and post submission. Any thoughts?
Thanks.
RobertAnderson3
MVP Regular Contributor
You did indeed, it mentions BUG-000165769 - dateTime values overwritten when navigating through repeats.
What's new in ArcGIS Survey123 (June 2024) - Esri Community
As of release 3.20 Survey123 on June 24, 2024 this issue should be resolved.
PanGIS
I am struggling on the same, finger crossed I managed.
I would say that depends on the type of calculation, one solution does not fit all.
Have you tried to use "calculationMode=whenEmpty"
GeorgeClutterbuck
yeah tried that, looked fine on the desktop but then wrong on the field app, frustrating.
DougBrowning
MVP Esteemed Contributor
Wrap it in once() works well for me
GeorgeClutterbuck
did you just do once(now()) for the calculation and it was fine? or did you set the parameters field to manual also? I saw your previous response to a similar post.
DougBrowning
I have been using just once(now()) for years before the calculation modes were added.  So far been ok.
abureaux
MVP Frequent Contributor
I literally just had this come up after no issues. Will be trying once() myself (as @DougBrowning suggested).
RobertAnderson3
once() is definitely a good solution, I've been liking calculationMode=whenEmpty for calculations as well.
If you're just looking for it to capture now(), could you put it in the default column instead of the calculation column?
MatthewDesjardins
I am experiencing something similar, but I'm not sure if it's the same. For me, the issue occurs even if I'm not trying to use a default value, so a once(now()) doesn't seem to be relevant. Even if I do use that, or use calculationMode=whenEmpty, the same thing happens when the user manually enters a value.
In particular, the issue is that when you manually enter a time on the second repeat entry, if you page back to the first one it looks correct at first, but its value has actually changed if you try to submit it now; once you go back to the second and then return to the first again, it shows the same value as the second entry.
For me, it seems to happen with both time and dateTime questions, but not date questions.
However, the survey seems to work as expected when using the web app, as well as using a mobile application (I've only tested it on an iPad). But using the Windows Survey123 application, it behaves the exact same as Survey123 Connect does, with the time question being updated with the later repeat values.
Survey123 Connect is version 3.19.116, and Survey123 is version 3.19.121.
Edit: I tried it with a very simple form just containing these lines and no calculations. I also tried setting calculationMode to either manual or whenEmpty, despite there being no calculation being done, but it behaves the same.
typenamelabel
begin repeatTestRepeatTest Repeat
timeTestTimeTest Time
end repeat
KaijaKlauder
Having the same issue as described nicely by MatthewDesjardins, in both Survey123Connect and as implemented on mobile devices. Connect is version 3.19.116, and Survey123 is 3.19.121. The field is a time field but I confirmed that changing it to dateTime shows the same behavior.
I have tried calculationMode=whenEmpty and also calculationMode=Manual, in each or all of the bind::esri:parameters, parameters, and/or calculation fields, which did not change the behavior.
Using once(now()) in the calculation field (with or without parameter specifications) results in sequential time stamp values that stay put if the user scrolls between repeats, but if the user manually edits any time value, the manually-assigned value is copied to all repeats. It's a slight improvement, but unfortunately because the time field of the first repeat calling once(now()) autopopulates when the form is opened (even if it's on a later page), if I don't start using those repeats right away, the values are no longer fresh and would need to be manually edited to be accurate. I'm collecting time series of animal behavior data and concurrent environmental stimuli, so having correct initial times and subsequent times are central to the data collection. This workaround would also run into issues when trying to collect an "end time" field that by definition will need to be blank for a while.
Any other suggestions to try before I kludge in a text field and make users manually enter times?
