I posted the same content in the Field Maps community (Opening Survey123 form in Field Maps (created in 2... - Esri Community)
I built a mobile solution that leverages both Field Maps and Survey123 back in 2021. When users click the asset on the map in Field Maps, a hyper link is created with selected feature's attributes and some real-time calculated values.
I used Classic Map Viewer at that time, and things worked smoothly. Since 2022, it was not in much use, and today I found out that the URL parameter I've created does not work anymore.
Can someone advice where I need to look at it? or perhaps save it as (new) Map Viewer?
Here is a sample url being created on the fly (I replaced parameter values to random text as my data is not public)
arcgis-survey123://?itemID=ItemID&field:Structure_Number=0233&field:Structure_Name=TOWER%20BANK&field:Highway=17&field:Critical_Route=no&field:Asset_Type=BRIDGE&field:Service_Area=A6¢er=yvalue, xvlalue&callback=https://fieldmaps.arcgis.app/?
Addition:
With more investigation, I found callback and center worked, but if I include field/value in the URL the survey123 form is not loading. Is there something that has been changed since 2021?
Thank you.
Have you tried included URL Encoding? Below is part of a URL I'm generating to pass info from Field Maps to Survey123 and you can see red text where the Encoding has modified the URL.
arcgis-survey123://?itemID=###############&field%3Ainspection_number=9%20months&field%3Aplantation=Balingup&field%3Atenure=Freehold%20-%20DBCA&field%3Atree_species=P.RAD&field%3Ayears_planted=2023¢er=##.###%2C###.###&callback=https%3A%2F%2Ffieldmaps.arcgis.app...........
See this post here for a more indepth discussion around how my link is generated and URL encoding. Solved: Help with Survey123 link from Field Maps with call... - Esri Community
