Open specific survey in Survey123 inbox from ArcGIS Field Maps in editmode
4668
10
04-06-2022 05:15 AM
Niklasg
Hi community
How can I open a specific survey in ArcGIS Survey123 Inbox in edit mode from a URL in ArcGIS Field Maps?
Right now the link im using in a pop-up looks like this:
https://survey123.arcgis.app/?itemID=dbf5fe641fbc44cb97100a830e850908&folder=inbox&mode=edit&globali...
It does open the correct survey's inbox, however I can't get it to either query the list or open the specific survey based on its globalid, instead I see the full list of survey responses in the inbox.
Niklas
Tags (1)
Adam_Bourque
Any luck? I am also trying this as I can’t use q: due to my workflow needing to filter by address name or asset I’d name offline. Problem is, this code using filter will use records on device which is fine if they load it before hand but I can't even get it to work at all regardless of refreshing inbox before / after internet connectivity.
<p><a href="arcgis-survey123://?itemID=14505fc4d195405aa06de1ee200a8e9e&action=edit&folder=inbox&update=true&filter={address}"><img class="image_resized" style="width:54.83%;" src=" https://dabuttonfactory.com/button.png?t=Service+Line+Survey&amp;f=Roboto-Bold&amp;ts=22&amp;tc=fff&..." alt="Service Line Survey"></a> <span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(220, 20, 60);"><strong>{expression/expr3}</strong></font></span><span style="color:#000000;font-size:large;"><font style="background-color:rgb(255, 215, 0);"><strong>{expression/expr5}</strong></font></span><span style="color:#ffffff;font-size:large;"><font style="background-color:rgb(128, 128, 128);"><strong>{expression/expr4}</strong></font></span><span style="background-color:rgb(65,105,225);color:#ffffff;font-size:large;"><strong>{expression/expr6}</strong></span></p>
