Open existing record
870
10-27-2020 06:07 AM
EricStarn3
Hello All,
I see you can use a form to collect data and edit submitted survey data. What I was wondering is can you scan using a barcode and open an existing feature from a feature service? For example I have a feature service of lights and I create a form based off of that feature service. Then a worker can go out and scan the barcode on light and pull up data from feature service to use or edit.
Respectfully,
Eric
Shwu-jingJeng
Hi Eric,
The feature you are asking could be this enhancement request we had implemented in 3.10.
ENH-000116357 With Survey123 for ArcGIS, allow barcodes to be used to search for existing features in the Inbox
Could you give it a try using version 3.10 or the latest one with your workflow to see if it works?
