Offline Basemaps without using Tile Package?
7729
10
03-16-2016 02:48 AM
CarmelConnolly
Hi Survey123 community,
Great work so far with the Survey123 app!
The offline basemap capability introduced in January was fab push forward in offline use: https://community.esri.com/groups/survey123/blog/2016/01/06/prepare-basemaps-for-offline-use.
Are there any plans in place to have a workflow implemented to take basemaps offline, similar to how you would in Collector?: https://doc.arcgis.com/en/collector/android/collect-data/offline-use.htm#GUID-71368F3F-2502-48BA-8BD...
Any information would be appreciated!
Carmel
by Anonymous User
Not applicable
Hi Pam,
Can you please share the tpk file you created and your xlsx file?
Are you using a custom tile schema, is does it match the Esri default? Survey123 does not currently support custom tile schemas.
We are currently working on a new feature enhancement that is currently in the early stage of development, which will allow using custom basemaps such as mmpk, vtpk, tpks and web maps in Survey123. Please keep an eye out for this update once it is available on EAC for early beta testing.
Phil.
