Offline Basemaps without using Tile Package?
7717
10
03-16-2016 02:48 AM
CarmelConnolly
Hi Survey123 community,
Great work so far with the Survey123 app!
The offline basemap capability introduced in January was fab push forward in offline use: https://community.esri.com/groups/survey123/blog/2016/01/06/prepare-basemaps-for-offline-use.
Are there any plans in place to have a workflow implemented to take basemaps offline, similar to how you would in Collector?: https://doc.arcgis.com/en/collector/android/collect-data/offline-use.htm#GUID-71368F3F-2502-48BA-8BD...
Any information would be appreciated!
Carmel
RebeccaStrauch__GISP
Carmel,
you may want to try Moving Content​    to the Survey123 for ArcGIS​   group (currently is in the ArcGIS Online group).  You will most likely get more Survey123 specific advice.  You can always "Tag" other groups by using the @ and the group name.  you can see the geonet structure GeoNet Community Structure
BTW, but including the Survey123 for ArcGIS name above, that did already tag that group.
CarmelConnolly
Hi Rebecca,
Thank you! I was trying to figure out how to do that yesterday - I've followed the group today and it's worked!
You can also go up a level to the space's home page by click the groups name in the breadcrumb string, so you can "join the group"
So that is all just Geonet help.....
Hopefully Ismael Chivite or others are monitoring and can answer your Survey 123 question. (I can not)
Nicole_Ueberschär
ichivite-esristaff, is there any news about having offline maps in Survey123 without the need of having a tpk installed?
IsmaelChivite
Esri Notable Contributor
Hi Nicole, no news for now.
Nicole_Ueberschär
JennyHuang3
Ismael Chivite‌ what about using the offline basemap downloaded in collector in survey123. is it possible?
thank you so much!!!
IsmaelChivite
Hi. Unfortunately not.  You cannot share basemaps across apps.
by Anonymous User
Not applicable
Are there any plans to improve Survey123's basemaps?
I've been trying for days to get Survey123 Connect 3.3.51 to recognize the existence of a 5.6 MB tpk file created with Tile Package Kreator 1.3.30. I'm editing the .info file with Brackets 1.13.
This all seems like such a clunky process compared to Collector.
