ODK Validate Errors: >>XForm is invalid
1813
04-22-2020 01:21 AM
MeganLaws
This appeared after branching the survey questions. Can anyone help?
DougBrowning
MVP Esteemed Contributor
You cannot have a ' inside of a ' quoted string.  You can switch to " " instead.  So use "don't know".  Same if you wanted " you would wrap in ' instead.
Hope that helps.
MeganLaws
Hi Doug,
Thanks for your reply. I had the same error when adding changing Don't know to "Don't know", also because I couldn't change the multiple choice entries since I had already published it (curiously without any problems that time).
I created a copy of the survey I had published that I was trying to edit, and then changed Don't to Do not and that did the trick!
Thanks.
