ODK validate error: form is invalid Survey123 Connect
2420
11-16-2021 01:03 PM
Hayley
Hi there,
I am trying to create a survey using an xls form in Connect however am getting this error:
"Encountered a problem with readonly condition for note [${Building_1}] at line: multiline predicitivetext, couldn't understand the expression starting at this point"
Any pointers on how to fix this? I have attached the xls form below.
Thank you!
HL
DougBrowning
MVP Esteemed Contributor
Looks like you did a copy/paste from a diff form and the columns did not line up correctly.  They changed the order a bit ago so old forms will not paste in correctly.  Like you have field-list for read only which is not valid (just yes/no).
Also it is complaining on links.  This means you used Ctl-C V which makes a link to the original sheet.  You always want to right click Paste Values in 123.  All your drops downs are messed up now too.
I suggest you start with a new survey and go column by column and use Paste values to clean it all up.
Hope that helps
DougBrowning
Hope that helps
Hayley
Hi Doug,
That did the job, thank you! Helpful to know 🙂
HL
