objectid pass through
1026
10-21-2019 05:52 AM
JoeLivoti
I have created a survey for a building inspector. What I would like is for him to be able to go to the map online, click the point of inspection, then click the link I have provided in the popup and it'll open up the correct survey that he can then mark approved or not. Where I am running into problems, is that to edit a particular survey you need the correct objectid. How can I pass the objectid through in the url? Here is the url:
 https://survey123.arcgis.com/share/1000dc184d944df9ad1cef1c2c3cea4d?mode=edit&objectId=1
Where the 1 is, I need that to be dynamic to the point and populate that field with that points objectid. I'm sure it's something simple and any help would be much appreciated.
ZhifangWang
Hi Joe,
Thanks for reaching to us.
If you mean the popup in a web map, you can configure the popup in Map Viewer by using the pattern {fieldname} to insert a field value dynamically in the popup. I found a clue in the doc Integrate with other apps—Survey123 for ArcGIS | Documentation and tried the settings in the attached image below. Would you mind having a try to see if this is what you want?
Zhifang
