Non-Relevant Questions Zeroing Out Existing Data
1391
11-16-2021 07:48 AM
JasonJordan00
Is anyone aware of issues when opening a web form in editing mode of existing data, if a question is not relevant it still pushes back a null value?
I have had several forms where this has been an issue. For instance, we have an a layer of features that assessments are conducted on. The form opens up to edit these features and fill out the assessment information. Normally one would enter a date and submit. However if a 'Reassessment' box is checked, that date is hidden and a reassessment date appears instead. I would expect when submitting on a reassessment it would just ignore this first date however the form appears to be submitting 'Null' and then zeroing out the existing data.
DougBrowning
MVP Esteemed Contributor
Nope if a field is not relevant it gets empty string period.  That is just how 123 manages relevant.
I think you want the newer hidden type using the body::esri:visible column.  This way just hides the values vs setting them to null.
For me a reassessment should always be a new form. Otherwise spatial, editor tracking all of that is lost.
Hope that helps.
JasonJordan00
I'll try the visible column, thanks. The forms are more complex than I've let on but there are reasons it's set up the way it is.
VMitch
The visible column worked for myself, and also agree with Doug Browning re a reassessment being a new form. Good luck.
