No puedo ver mi formulario en Arcgis On line
330
01-28-2022 07:03 AM
GerardoContreras
Hola a todos, realicé un formulario a través de connect pero al tratar de visualizarlo en arcgis on line, no puedo ver los puntos geocodificados. Ayuda por favor. gracias
by Anonymous User
Not applicable
Hi @GerardoContreras,
Based on Google Translate, you are having the following issue:
Hello everyone, I made a form through connect but when I try to view it in arcgis online, I cannot see the geocoded points. Please help. Thank you.
Are you able to share your XLSForm you published from Connect (and which version you used), and also screenshots of the issue (ie what points are missing and from where)?
Are you using repeats, are you viewing in a web map or survey123 website?
Regards,
Phil.
