No Dynamic Content Available (Survey123 Power Automate)
1370
09-05-2023 01:37 PM
icf_Eric_Link
I've created one flow successfully that uses the survey123 trigger, creates report, attaches report and then emails attachment.  I am trying to create the exact same flow except using a different form.  The issue I am running into is that when I add the create report I'm not getting any dynamic content to choose from.
Does anyone have any ideas as to why this is happening and a fix?
ZacharySutherby
Hello @icf_Eric_Link
This is usually from the connection to your ArcGIS organization being expired. If you navigate to Data > Connections > select the three dots to the right of your Survey123 connection > select switch account > reenter your ArcGIS credentials.
Thank you,
Zach
BethanyCrenshaw1
Hi @ZacharySutherby I am having the same issue with Power Automate not showing me dynamic content.  Some surveys work fine for me, but my current survey does not.  My goal is to have an email sent to the email the users select from a list in the form.
I have set up new connections and re-signed in. Do you have any other suggestions?
RobertAnderson3
MVP Regular Contributor
Do you have any groups without labels? That one always messes with me on some of my surveys.
